See MLT and SMLT Configuration Requirements to understand the commands you can use to add VLANs to an LACP-enabled MLT. Ensure you use the correct command to avoid the LACP churn condition.
Create MLT 40. Configure the private VLAN type for MLT 40 to isolated. Add VLAN 10 to the MLT. Enable the MLT.
Switch:1(config)#mlt 40 Switch:1(config)#mlt 40 private-vlan isolated Switch:1(config)#mlt 40 vlan 10 Switch:1(config)#mlt 40 enable
Display the MLT configuration:
Switch:1(config)#show mlt 40 ========================================================================================== Mlt Info ========================================================================================== PORT MLT MLT PORT VLAN MLTID IFINDEX NAME TYPE ADMIN CURRENT MEMBERS IDS ------------------------------------------------------------------------------------------ 40 6183 MLT-40 access norm norm 10 DESIGNATED LACP LACP MLTID IFINDEX PORTS ADMIN OPER ------------------------------------------------------------------------------------------ 40 6183 null disable down WHICH PORTS WHERE LOCAL REMOTE PROGRAMMED MLTID NAME CREATED PORT MEMBERS PORT MEMBERS IN DATA PATH ------------------------------------------------------------------------------------------ 40 MLT-40 LOCAL NONE ENCAP PVLAN VID MLTID IFINDEX DOT1Q LOSSLESS PVLAN TYPE TYPE FLEX-UNI ------------------------------------------------------------------------------------------ 40 6183 disable disable enable isolated secondary disable
Use the data in the following table to use the mlt command.
Variable |
Value |
enable |
Creates and enables a new MLT. |
encapsulation dot1q |
Enables trunking on the MLT. |
member {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Adds ports to the MLT. Identifies the
slot and port in one of the following formats:
<1-512> |
Specifies the MLT ID. |
name WORD<0-64> |
Configures the name for the MLT. |
private-vlan {isolated|promiscuous|trunk} |
Specifies a private VLAN type for the MLT. |
vlan <1-4059> |
Specifies a VLAN ID to add to the MLT. |
